Need a few oddball pieces
jdpolzin
Looking to see if anybody can help me find these pieces for CHEAP. I had everything and now cant find them since I moved. I need the vacuum ball under the drivers front wheel well, the two small rods that cross in front of the radiator support, the rubber mats that go on the two sides of the radiator and under it, and the two small plastic blocks that go between the core support and the lower air dam. I have one of the plastic blocks but not sure which side it is.
I have plenty of parts to trade if you may be loking for something. Thanks for the help guys!
I have the core support rods nicely powdercoated. Looking for valve cover bolts, stock off course. It's a shame I was at a yard today I could of gotten all those things. Of course I forgot the radiator baffles. I do have one sitting in the garage though.
Do ou need the whole set of valve cover bolts? I should have them. I need to check at my old house becuase all of my bolts are there.
Jeremy,
I should have everything else. I will look tomorrow. You're not needing "like new", I hope, since you want "cheap" :)
Nope doesnt need to be new. Just functional. Thanks for the help! ---Jeremy
Im looking for a complete set but I definitely need the tall one that the wastegate actuator mounts to on the passangerside valve cover.
also need a few dash screws that hold the speaker plate in place the ones with the torx heads.
Jeremy,
I do not have the blocks under the rad support. One is missing, the other broken. I have the vac ball and the rad shrouds. Bottom shroud is nice, one tear between a mounting hole and a rectangular slot. Otherwise very nice. Came off my car about 20 years ago. The sides are in fair/good shape, rougher but no tears. I would also have the cross braces if needed.
Let me know the address.
Ill find those for u! If john has the bars, might as well get it all from him but either way, ill see what all I have and send them to u. Pm me your address and I should be able to get them in the mail this weekend. Jeremy
I agree Johns a good guy as well. I'll send a PM let me know what I owe you.
