- Nov 24, 2001
WELL-
its snowing out today, so took the day off and im putting the parts on my new 3.8 motor-
after reading the RJC GIRDLE instructions, it says to use a Duttweiler cork pan gasket- of course there is 6 inches of snow out, and i have a felpro silicone gasket here at the house
Q- should i wait and get a cork gasket from NAPA, or acutally get a Duttweiler cork gasket---
the machine shop built the short block, and installed the GIRDLE and i believe they put the brass washers in the incorrect spots
per the instructions, the M8 FLAT WASHERS STAMPED "B" are supposed to be located, USE WITH UNDER GRADE 8 NUTS SECURING GIRDLE-
Q- so the "B" washers are supposed to touch the girdle, then crank down on the nuts, and then install the sealing washers?
MY flat washers stamped "B" are still in the bag, and the other 15 washers BRASS SEALING WASHERS .695X.315X.05 ARE under the nuts holding the girdle on the block-
let me guess, if i dont get this right, its going to leak like a S.O.B. AND i will have to pull the motor back out when i get p.o'd at it??
thanks in advanced guys, i need these Q's answered soon
ps- what kind of RTV did you guys use to seal between the bottom of the timing cover and girdle??
pss-
Q- will stock oil pump gears work with a aftermarket high volume front cover??
im missing the gears and seal that presses in the front of the cover, can i get it at NAPA??
THANK YOU
pss-
THANK YOU
