Need A Picture For Tach & Fuel Tap
trixdout
Connectors and where they plug into. Can anyone assist with that or a link to where I can see where it plugs into. Looked for over an hour and still couldn't figure it out.
Correct they do not plug into anything. Fuel tap can be connected to a power source to drain your fuel tank if needed. Tach tap is for a signal to an aftermarket Tachometer.
Bryan
I have a total of 3 plug in connection, one behind the alternator and the two others nearest the power steering pump. Does anyone know the actions of these 3 connections? One is to drain fuel , two is an aftermarket tach and ????
