jskarateka
- Nov 16, 2008
Been trying to get some decent 60ft times at the track with my setup. I have been practicing and reading other threads, but could use some specific advise from you guys. My best is 1.86 but I can usually only manage around 2.00.
I don’t have the best setup for a good launch; No suspension upgrades other than a Kirban pinion snubber. Nitto 275/50 15 drag radials on stock GN wheels. 2400-2500 restalled D5 converter at 5psi. I plan on getting a looser converter in the future but my job is in jeopardy now and I can't do it at this time.
My car does build and hold boost well at the line. (10+ psi is no problem). I usually try and leave about 6 psi. Lower than that and its a little flat leaving the line because of the low RPMs. Higher than that I wind up loosing traction
My questions are:
1) What tire pressure at the track would you recommend on the Nitto's.
2) Do you guys always release the foot brake instantly, or do you "roll" it off to help maintain traction at higher boost?
3) Burn out or no burn out? I've read some that say it doesn't help much with drag radials.
4) Any other advice?
The car does run well at the track. My best ET since I installed the Alky was 13.20 @ 106.9 with a spinning 60ft time of 2.27. Couldn't hook all day but it was April in Chicago (60 degrees and overcast). Opening weekend at track, conditions sucked.
Thanks guys.
My questions are:
Thanks guys.
