S Spot84 Nebraska Joined May 31, 2017 Jul 17, 2017 #1 Does anyone have a new alradco radiator hidin' in the corner of their shop? Thanks fellas!
N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Jul 17, 2017 #2 I have this alum radiator with or w/o the fan in stock. The complete unit with the radiator, dual fans, plug-and-play harness with 2 relays for $699, radiator only $499.
S Spot84 Nebraska Joined May 31, 2017 Jul 18, 2017 #3 Do you run this particular setup in your car? If so, how well does it cool?
N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Jul 22, 2017 #5 Spot84 said: Do you run this particular setup in your car? If so, how well does it cool? Click to expand... I have not driven the car is 110+ degree temps, but at over 100 degree weather the coolant temp is well below 200 degrees with cold AC! The engine is well built to produce over 600 RWHP.
S Spot84 Nebraska Joined May 31, 2017 Jul 22, 2017 #6 Nick Micale said: I have not driven the car is 110+ degree temps, but at over 100 degree weather the coolant temp is well below 200 degrees with cold AC! The engine is well built to produce over 600 RWHP. Click to expand... Awesome! I really appreciate the info Nick!
2QUICK2B6 Black Car Fever Joined Sep 15, 2004 Jul 22, 2017 #7 Looks like a nice set up what brand fans are those
