need help cant find the right tires
greg wilson
im having a hard time finding tires for my stock rims 87 gn, i have nittos in the rear 275 60 15s ,and factory 215s up front i want to go with a little wider tire up front, what do you recommend,and what are you guys running up front with the stock rims. i called the tire rack and they told me they dont make that many tires for our cars anymore.like i said i want to go wider but i also want the be safe thanks.
I use 235/60/15 Michelin Pilots, not cheap but work good with the Nittos.
I use them on both cars with Am. Racing 7" rims to match the 8" Am Racing rims out back.
They would also fit the stock rims too.
Reminds me I need to order a pair of Blizzaks for the winter. ;)
Tires
P235/60R15 up front will fit just fine with stock 7" rims and not rub. BFG T/A's are good street tires.. TireRack.com sells them, as do many other places. I bought Yokohama Avid's in that size from TireRack.com 'cause they were a little cheaper and I wanted to have a little money left over for the DRAG RADIALS I'm gonna get. HTH
235/60/R15's...........same height as factory, but wider. Fits on factory rims. No rubbing issues either! That's the way to go upfront.
I went w/ the 235/60/15's on a goodyear eagle #1 nascar. 8.1" tread-width. :)
Yup....if you're looking for a good ( and good looking ) tire fairly cheap look at a Mastercraft Avenger GT. Pretty much looks like a Radial TA but cheaper.
