I can not get my wide band o2 to work, It is not showing up on the bottom right corner of the screen ! Also i can not get the computer to go into closed loop. I have all the setting set so it should turn on at idle. There is no o2 correction going on. All the requiremtns are met. Temp, rpm and time . So what is keeping it from going into close loop. I read some other post about this. And there was mention that it willl not go into closed loop if there is any after fuleing corrections. So i looked at the graph and the little cross hair is at 180 degress and +80 enrichment. Please help!!!
. I am using bosch o2's. For the regular o2s. The number for my wideband matches that of my computer. There is no symbol (lambada) in the lower right corner. How would i tell if it is wired correctly. The wideband sensor does not heat up with the key forward. Will the lambada symbol be there even if it is wired wrong.
![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
