NEED HELP! Ground Wire
  • Thread starter Thread starter Quick231
  • Start date Start date
Q
Quick231
Guest
Just install a new rebuild engine. I cannot remember, where do I hook the flat ground wire that is connected to the car behind coil pack. Does it ground from the firewall to the back of the driverside head or does it go somewhere else. I can't remember! Also on the starter besides the positive wire connection and the little wire connection does anything else connect to it. I would appreciate any help.
I believe the flat Grd Wire you are talking about is the copper braided one. It goes under the head of the small 10mm bolt holding the coilpack bracket leg to the intake manifold on the drivers side and the other end goes to the firewall. Make sure there is no paint on the bracket leg so it will ground well. Coilpack is grounded through this wire.
Mitch
