87 GN STOCK TURBO,F/M INTERCOOLER, 3'' DOWN PIPE, STOCK INJECTORS,NEW TT CHIP, CAR RUNS GOOD TILL THS BOOST GETS ABOUT 15 THEN IT STARTS TO MISS OR CUT OUT IF NOT LET OFF OF BOOST IT WILL POP I DID JUST PUT NEW PLUGS IN AC CR42TS GAP .035. IT DIDNT DO THIS WITH 43'S IN IT. SCANMASTER #'S IDLE 02-52,TPS-.42,WOT-4.04,MAF 4,LV8-28, INT 128 BLM 142 2.1 RETARD DEGREES THE CHIP IS NEW PUT IN TODAY DID THIS BEFORE ICHANGED THE CHIP. THE CHIP WAS BURNED FOR THE CAR AND WHAT I HAVE ON IT. FUEL PRESSURE IS 43 WITH VAC LINE OFF. PLEASE HELP:redface:
