That's why were here Bobby. Make sure to use some brake cleaner on them and the holes you're going to dive them in to for a good seal. If you want to use any sealant then use Indian Head Gasket cement. It won't cause you any problems and will help to seal any imperfections. Stake the plugs in good so they don't decide to back out when you check for pressure again.
