Ok just finished my te63-1 install with bigger injectors, modified ecu, and chip. I got the car running and when I get into it, it only see about 2-3psi on the boost gauge. I hooked up the wastegate and compressor vac. line to the factory boost solenoid and left the one next to it completly open. I checked the wastgate actuator and it appears to be opening with a tool that I have here at work. I also checked all my intercooler connection for any possible leaks by taking carb. cleaner and spraying it on the IC couplings to watch for a stall or high rev in the motor. Still no luck with any of the tests that I have done. My vac. gauge is showing 10 inches of vac. at idle, shouldn't I be seeing atleast 15 at idle? Any suggestions? Thank for your time.
