Okay i got home an yes i do have positve power on the harness n the injectors but still no negative when cranking ...
I do see the light blink on the noid light very dim when i jump crank b and c but just for a brief moment
I would say the ecm under the coil then.Ive used autozone/oreilly ones .Many brand new ones in a row ,and they didnt work.I ended up finding an original used one,it worked perfectly.
These things are weird like that.
im thinking it might be the ecm i got this one from a member from this site he claimed it was good but it might not just be a good one .... so ama have to go look for another one or find some one here in arizona if they can test it in there car see if it starts there car
i dont really want to start trowing parts at it with knowing if its really that .
an yes i have constant voltage on the inj harness as well i have power on cam an crank
12.28v injector harness
5.48v on the cam signal
10.30 before crank 8.09 while cranking on the crank sensor signal side
all this at the ign module side
Well update
Great news guys an i appreciate all the help that you guys gave me well i found the problem a it had to do with the crank sensor pigtail when i first got the harness it had the crank sensor pigtail cut of so i purchased a new one it cane with the same color coded wiring so i didnt think nothing of it but after weeks of headaches an many parts changed i i looked once again on vortexbuicks an noticed the wiring was wrong the signal an the 12v were flipped around .... once again thank you all
An also nick for guiding me on this build ...
