SignUp Now!Looks like it wasn't welded on correctly to meet up with the turbo. You could have it rewelded at the right height.
Sent from my iPhone using Tapatalk Pro
I purchased it this way from ebay...guess thats where I went wrong. $***!!!!
Are you able to re-clock the housing?
Try to loosen the bolts on the cold side of the turbo and move the housing. Not sure from the pic if you can move it enough to make it work.
It looks like you should able to loosen the bolts on the compressor housing and rotate it up to match the intercooler.
I’d first loosen the compressor cover bolts and the Intercooler bracket bolts and see if you can clock the cover into a better position and slide the hose on place then tighten the Intercooler bracket bolts and comp cover bolts
Hey Bison!! So this is one of your MFS 5957's I purchased this year. I was able to loosen the compressor cover bolts and clock it. Thank you all for helping me out with this...
