mikeandjen
- Sep 14, 2007
Hey guys,
I put in the motor I had bought from Chris and hooked everything up....put the new bearings in and each was clearanced at .0015 with plastigage....
However, on startup the car built about 60psi of oil pressure and then shortly after throws code 43....esc failure/engine noise.
So to diagnose this is what I have done:
Changed knock sensor with a new one, and the one of my other motor which had no issues-still same code and car shuts down
Checked the ESC module and tried a new one.....same code pops up after resetting computer and shuts down
checked the wires at the ESC module and has ground continuity, power to the correct wire and also continuity to the purple wire at the knock sensor.....what am I missing guys?
If the ground was not on the motor I wouldn't have ground at the ESC so rules that out........
Could the motor really be making that much noise to set this off? It doesn't seem to be running rough per say, firing in the correct order, just as soon as the light is set off pulls about 14.4 degrees of timing on the scanmaster and starts running like crap
I can't keep the car running long enough after the timing is starting to be pulled to check anything else, the tps is good and in range, iac seems a little high, no other codes are coming up on the scanmaster.....
HELP! PLEASE!
Mike
HELP! PLEASE!
Mike
