Hello.. I´m the owner of the car.
Thanks for searching for help here "Swede2", I did not even think of that first.
The setup I have now in FAST is done by Sod Bogosian at HYE TECH PERFORMANCE. From what I have heard he is good at these things.
The car, which I bought from Randy Burg, CA in the ending of march is not stock at all. But no, it does not have 83# injectors..
I include what is in the car at the bottom of this post.
Is it possible that FAST has resetted or just deleted everthing that was in there?
The car just started to run really bad when I was out driving. I was not pushing it in any way, just crusing around really slow on the streets.
I don´t even know if the problem is in FAST or somewhere else.
But what I have done so far is:
- Put in new spark plugs, the ones that was in was all black and "wet".
- New spark plug wires.
- New coil pack
- New battery
- I have checked battery grounds, vacuum hoses and all the wiring/connectors I could find. Did not find anything that seems to be wrong/broken.
The MSD box lights up and seems to be working as well.
I would not be suprised if it was something wrong with the FAST setup, but the wierd thing then is that I have not changed anything there. The first time I connected my lap top to it was after the car started to run bad.
Hopw you understand my lousy English..
I'm thankful for all help and tips I can get.
/Daniel
Here is the list on parts that is in my car:
INTAKE AND EXHAUST
4” K&N AIR FILTER & EASTERN PERFORMANCE 4” INLET PIPE
T72 TURBONETICS CERAMIC BALL BEARING 72 MM TURBO
TONY DEQUICK FRONT MOUNT AIR TO AIR INTERCOOLER
KENNE-BELL 70MM THROTTLE BODY AND INTAKE PLENUM
MATCHING 1” PLENUM SPACER
ATR EXTERNAL WASTEGATE & MANUAL BOOST CONTROL
CERAMIC-COATED STAINLESS STEEL FACTORY HEADERS
3” STAINLESS STEEL, CERAMIC COATED DOWNPIPE
3” STAINLESS STEEL CAT-BACK ATR “PITBULL” EXHAUST
ENGINE WORK
PORTED AND POLISHED O-RINGED CHAMPION HEADS
CUSTOM ROLLER-FULCRUM ROCKERS
CRANE 212/212 ROLLER CAM
CUSTOM ROSS 9.0:1 CR PISTONS
STEEL MAIN CAPS
NITRITE COATED STEEL CRANK
COMPLETE BALANCE & BLUEPRINT
A/C COMPRESSOR DELETE PULLEY AND BRACKET
IGNITION AND FUEL
“F.A.S.T.” BANK-TO-BANK FUEL-AIR-SPARK MANAGEMENT
WIDE BAND O2 SENSOR
MSD DIS-4 PROGRAMABLE CAPACITOR DISCHARGE MODULE
POWERMASTER 120 AMP ALTERNATOR
REAR MOUNTED OPTIMA BATTERY IN A MOROSO BOX
WALBRO IN-TANK FUEL PUMP WITH ½” FUEL LINE
72 LB/HR SEIMENS INJECTORS
FLAMING RIVER REMOTE BATTERY DISCONNECT
SMC ALCOHOL INJECTION WITH BOOST SENSOR
DRIVELINE AND SUSPENSION
SPECIAL SOFT COMPOUND GOODYEAR EAGLE TIRES
FORD 9” REAR END WITH DETROIT LOCKER AND 3.50:1 RATIO BY CURRIE
PST CARBON FIBER DRIVE SHAFT
KENYON BUILT 200-4R, TRANSGO SHIFT KIT & TRANS BRAKE
3600 STALL PRECISION LOCK-UP TORQUE CONVERTER
SPOHN TORQUE ARM AND DRIVESHAFT LOOP
HOTCHKIS REAR SWAY BAR, END LINKS AND PANHARD ROD
BMC STRUT TOWER BRACE
ALSTON WELDED IN FRAME CONNECTORS
KB SHOCKS
INTERIOR
SPEAKER UPGRADE – STOCK LOCATION (NOT VISIBLE)
STOCK FACTORY AM/FM CASSETTE WITH POWER AMPLIFIER
SONY 10 CD PLAYER INSTALLED IN TRUNK
