Randy just told me this:
It would cost me more $$$ again and it will probably be alot of work.
If anyone is willing to help me set up this FAST computer on "long distance" I willing to pay that guy the $$$$ instead.
Jason Dale installed the FAST computer and removed the stock computer. I don't know what things need to be changed to put it back to stock. I do know that you will need a large Mass airflow sensor made by Granatelli (look on the internet or in a Summitt or Jegs catalog). The TTA does not have a Mass airflow sensor now because the FAST system does not need it. It installs on the intake pipe right after the air filter. Also, the injectors need to be changed to 50 lb. and you must buy a computer chip to match the injectors. You should write an email to Jason Dale to ask everything that needs to be changed to put back the stock computer. Ask Uffe if he has any Computer chips that go with 50# injectors. I say 50# injectors because you have a very healthy cam and a large turbo, so you need to get the biggest injectors that can work with a stock computer.
