Battery reads at 12.5 not running (with a volt meter after a drive). Replaced altenator with a new pro-start 120amp from Pep Boys. Made sure battery terminals are tight as well as the ground by the oil filter. Scanmaster reads around 11.5-12.2 at idle and 12-13.3 under load whats wierd is a couple times Ive seen it fall to 6 something and go back up to the above mentioned volts. The other day my third brake light started working which hasnt worked since I bought the car 6mths ago then it wouldnt go off even with the ignition turned off, now its back to not working again at all.
I am running half 91pump gas and half 109 race gas as well as Razors Alcohol which haas a bad diafram in the pump at the moment so Im not sure if its spraying all the time but I figured I shouldnt be getting knock with the 109 added but Im getting knock as if im running on straight pump gas. Any suggestions? or advise?
