Need Help with Pressure Readings !!!
boostmaster
I've been having a flare issue @ wot and finnally took some pressure readings today, Here's what I found.
All readings were taken @ 1000 rpm's
min tv max tv
P - 80 200
R - 100 200
N - 80 200
OD- 90 180
D - 90 180
2 - 180 180
1 - 180 180
Also took a reading @ wot from a standing start and gauge stayed locked @ 110 PSI never increased or dropped. Any help would greatly be greatly appreciated.
I'll give it a shot
You could have a weak pump slide spring, try just bring the RPM up in neutral to about 4500 & see if the press. drops.
Or when you launch it might be uncovering the pickup, but then it should recover or at least change.
Hope this helps.
