Oct 11, 2008 #1 G G-Force Member Joined May 24, 2001 Messages 559 32 EGR Vacuum Error 35 IAC Error 41 TACH Input Error 42 Open Est/Bypass Circuit. Spend the better half of the morning trying to fix this with no luck. IAC reading is a constant 0 on my OTC.
Oct 14, 2008 #2 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 G-Force said: 32 EGR Vacuum Error 35 IAC Error 41 TACH Input Error 42 Open Est/Bypass Circuit. Spend the better half of the morning trying to fix this with no luck. IAC reading is a constant 0 on my OTC. Click to expand... A leaking EGR valve will give you the first 2 errors. A bad ignition module or bad connections to the module will give you the 2nd two errors.
