Upgraded from 1.34 to 2.002 and thought I'd try the boost controller. I'm set to Map mode and slew is 1000 Pos. and 1000 Neg. PID is set at P=80 I=30 D=30 and the boost table is set to 65 strait across 0 tps to 100 tps. The problem I'm having is the boost duty cycle stays at 100 until 14.5 psi to start falling and by the time it gets control of the boost it's at 20 psi. Would ramping the boost table help this even though I'm at 100 tps way be for 14.5. tried moving the pid all around with no luck if i lower the (i) lower than 20 the duty cycle falls to slow. Any help would be great I'd like to get this working.
