Drove the car to work and it ran flawlessly. Went out to start it and it started for about a second, got real rough and died. Will not start at all. Have tested and replaced with know good coilpack, MAF, ignition module, crank sensor, plugs, and wires. It has spark, good fuel pressure but just hits a little and thats it. I have gone through all tests in the manual and everything tests out. :frown: Have not removed the cam sensor as I don't have the tool to align it back. I am getting some fuel vapor out of the intake somewhat like a backfire but no pop. Drained oil and no antifreeze or particles in it. Could the cam gear that drives the sensor just have gone? Is there a procedure (without removing the front cover) to check cam timing with the crank and piston #1? Haven't been able to find the procedure to check time. Any help would be appreciated.
