Need Help
nvrenuff
Just put a 67 mm turbo on with an orange stripe convertor. The problem im having is i cant spool the turbo out of the hole. The orange stripe is only stalling to about 2000 rpm and im leaving with no boost. I need something good for 3000-3300. I called art carr and they said the one they have will stall at 3300 but lock up at about 4000 and that would cause problems. They had suggested using a 50 shot of nos to spool the turbo. I dont want to spray it so i need some help. I cant be the only one trying to do this.
Thanks Guys
Neil
Need more info. But one thing i can tell you is that you need a converter that has less of an rpm drop on shifts and more stall at 0 boost. The AC 9" 3000 stall works great with the PT67 p-trim. Spools easy and sits right in the power band the whole run. No N2O is needed.
