Maverick87
- May 25, 2017
I have a stock 2004r in my GN. I was going about 15mph, and went wot. It pulled for about 3sec and completely let go. Now it will click into all gears but barley moves if you rev it. It does make a very faint noise when in gear. I checked the line pressures, and this is the results.
1000rpm park. 65psi 1000rpm reverse. 120psi
100rpm over drive. 65psi
1000rpm drive. 65psi
1000rpm 2nd. 145psi
1000rpm 1st. 145psi
Tv line fully extended. 160psi
Any advice will be greatly appreciated, im not sure if its just the converter or something else? Thanks!
1000rpm 2nd. 145psi
1000rpm 1st. 145psi
