Ok guys I went to the track tonight for my first time tonight and did horrible
I got a 14.4 1/4
now this is my question
my car knocked really bad so I let off
it was 8.7degrees with 787 O2s
I was running about 47psi with the line off
my car has the following mods and services
rear main seal fixed
valve covers replaced and new gaskets
hooker exhaust
THDP test/dump
racetronix hotwire and fuel pump
all the gauges
scan master
RJC power plate
big neck intercooler
spring cleaning minus transmission change and rear end change
volt booster
big mouth intake
torque conveter lock up switch
adj fuel pressure regulator
thrasher 92 chip
pinion snubber
ramchargers boost controller
recalibrated speedo to 145mph
driverside header fixed
ok that is everything done
now here is my question
towards the end of the night I found out why it was knocking so bad
the boost was going up to 20psi for whatever reason
now if I run some race gas and xylene I would have run a faster time correct?
also I do have an adjustable wastegate at home should I put that in and adjust it to how many psi for pump? which way do I turn it too?
do these seem reasonable as too why I was knocking so bad?
what causes the boost to go that high also?
thank you very much and sorry for all the questions
Carl
I got a 14.4 1/4
hooker exhaust
THDP test/dump
all the gauges
scan master
RJC power plate
volt booster
big mouth intake
thrasher 92 chip
pinion snubber
Carl
