I had once thought about using injectors to do the trick, but there are several problems:
1: cost of injector
2: life of injector - seals don't hold up, from the drying, wetting, etc...
3: the frequency required - you would have to pulse it faster than one injector on a rail... much faster. The other option is to use several in sequence, but see # 1.
I would nix the solenoid idea... that is basically a "slower" and less robust F.I. Aquamist uses a solenoid but then again, they're only used for the wasser.
I've been working on something with a lil "freak-factor" to replace all this compatibility junk... but like I said, y'all will have to wait for that monster. Meh, it's not like it would be that cheap anyways but control would be, well let's just say, * good *
PS: does anyone know why they hell I'm watching Saved by the Bell on AdultSwim?
Phil
