turbojimmy
Supporting Member
- May 26, 2001
I'm going to try to get an objective opinion on the pictures below. They're of two of the main bearings in my GN. They're the only ones I've been able to remove so far. The car has a blown head gasket, that's the only thing I know for sure right now. When I started up I could hear what I think is the tell tale signs of hammered bearings.
Here's what I think, but don't let what I think affect your answer: I'm thinking that these pictures are of a destroyed bearing and that I would not have been able to drive the car with the bearings looking like that (assuming that all the others look like these). I'm thinking that this is not normal wear and is the cause of the squeaking/screeching.
The purpose of my question is to differentiate between damage done by the events that blew the head gasket versus normal wear. The car was running fine before the head gasket blew - would the car have run fine with bearings that look like these?
So the question is: is this normal wear or damage that would cause squeaking/screeching from the bearings?
4-5 Bearing:
2-3 Bearing:
TIA,
Jim
4-5 Bearing:
2-3 Bearing:
TIA,
Jim
