Need rod advise
boostmaster
Posted in this section cause I thought I would get a better response from some of you stage guys. I'm looking for a stock lenght rod or no longer than 6.2 with a .990 pin diameter for a stock stroke off center production type set up. These will be with full floating pistons. Any advise will be appreciated. Sorry but I can't answer any questions cause I am basically engine spec illiterate.
Dan Strezo at DLS would be a good guy to talk to about whats available.
Jason
How much power are you looking at making do you have pistons?? stroke??
Sorry don't know the compression hieght but they were designed to yield 9.1 compression ratio with a 6.2" rod.
If your intrested . send me a piston and I will figure this out for you!!
then maybe I can fix you up with the proper rods. let me know mike:cool:
