Need rod advise
boostmaster
Posted in this section cause I thought I would get a better response from some of you stage guys. I'm looking for a stock lenght rod or no longer than 6.2 with a .990 pin diameter for a stock stroke off center production type set up. These will be with full floating pistons. Any advise will be appreciated. Sorry but I can't answer any questions cause I am basically engine spec illiterate.
Dan Strezo at DLS would be a good guy to talk to about whats available.
Jason
Sorry don't know the compression hieght but they were designed to yield 9.1 compression ratio with a 6.2" rod.
If your intrested . send me a piston and I will figure this out for you!!
then maybe I can fix you up with the proper rods. let me know mike:cool:
