Car ran great until today. Taking it back to the garage to put her away , did a small test hit. Left at 0 boost and had a smooth clean pull with no knock upto about 60 and let out. That's when the car started bucking like it was about to stall out. Kinda felt like I blew off a vac line, but that's wasn't the case as far as I can tell. Thought maybe fuel pump took a shit, but fp was on the mark and so was the vac at idle at about 18. Check to see if any plug wires were lose and they were good. Brake boosted the car while at the house and it starts to cut out and acts like its about to stall. Did it again after it idles for a minute or two and it built boost like its supposed to. So something is cutting out. Not sure if it's fuel or electrical. Any ideas where I can start to diagnose this. Far as I know ign coil is stock as a friend mentioned that may be a culprit. Need some help. Thanks
