need some electrical help
jwheelz1212
the 20 amp fuse that runs my power antenna interior lights, radio, locks ect. i have searched all over the car trying to figure out he problem and cant find anything wrong. any help would be greatly appreciated
thanks guys
Assuming you have a short and the fuse is blowing, check the cigar lighter socket, remove the orange power wire from the back of it, it usually shorts at the mount where it snaps into the metal part.
Underhood light wire can break and short.
Footwell or glove box lights or trunk light can break the wire and short out as well.
i will check it over tomorrow thanks for the help. do happen to know where all the grounds are?
Most of those devices are switched and self-grounding as in always hot via that fuse and opening the hood, trunk, glove box etc. grounds the circuit.
Same with the footwell lamps.
The frame of the cigar lighter is usually what shorts out.
