Hi,
Go to Alldata.com, buy the package for your car, and you'll have everything the pros would use , for your vehicle only. It's very affordable, too affordable, if you ask me, as I am one of those pros paying a bunch of money monthly for complete access. Se La Vie in the internet age, I guess...
Several other notes for you. One of the most effective deterrents out there is that column collar mentioned earlier.The permanent installation stainless jobs are getting hard to come by, but they sure put a fly in the ointment for any punk with a stanley screwdriver in his pocket. Also, you could install an ultrachip, with thumbwheel control, which incorporates an antitheft setting. They are pretty cheap, but the various boost settings may not be to your liking. I don't think they are dialled in as well as some of the other chips.
Finally, since the fuel pump connector is so easy to get at,I usually disconnect it too, and set the ebrake and cut the wheels all the way, making it as hard as possible for even the thieves using wreckers. All of this should keep your vehicle out of the reach of thieves pretty certainly.
