boostedyards86
- Jul 5, 2010
clean ur pcv valves or breathers whatever you have. Pull off the intercooler and clean it as well as check turbo for shaft play.
SignUp Now!I would deff. Check that cold air intake, it looks like its not on the inlet bell too good...MikeThis is another area that caught my attention. It's leaking a little bit of oil after the intercooler. It that a sign of a bad turbo seal?
Here is one of the plugs I pulled. They are AC Delco R42TS. Is this the correct heat range, or is it too cold of a plug? Also, does this plug look fouled to you?
View attachment 177590View attachment 177591
mikes86ttop said:I would deff. Check that cold air intake, it looks like its not on the inlet bell too good...Mike
I took some pictures today! Hopefully you guys will be able to help me out. I didn't see the these injectors on the parts list in this thread, so I have no idea if it matches the chip or not. If you can't tell from the pictures, the injectors part number is D1720BA. Then on the other side of the injector is has the number 24.
My Hypertech chip number is #41372 and the serial number is #0018592. The box looks like its from the stone age haha. It also says stage 2 on there. Is this the correct chip for these injectors? Have you ever heard anything good about hypertech chips?
Here is a picture of the coilpack, which appears to be stock. It's leaking out this blue stuff. Is that normal?View attachment 177586
I think your plug looks fine http://www.ngksparkplugs.com/tech_support/spark_plugs/faqs/faqread.aspHere is one of the plugs I pulled. They are AC Delco R42TS. Is this the correct heat range, or is it too cold of a plug? Also, does this plug look fouled to you?
Stock was 28 lbs http://www.gnttype.org/maint/turbox.htmlThanks for all the help guys! So you're saying I actually don't have bigger injectors? They're just stock replacements? Was 32lb injectors stock?
Were you able to tell if the chip and injectors had the same flow rate?
