As i will alway's gladly take advice from member's i really prefer pro advice on my tune..
Now im having a few issuesi have dropped the boost down to test so im around 26#'s give or take..i have ran 31 psi +without a problem but i want to make sure my tune is on the good side as i will be going to track this weekend hopefully run some good times...
1.Seem to be having high bl's on top of 3rd ive tried adding fuel on the tables as you will see on both PL file's..i do have a FP gauge i need to install but my IDC is in good percentage..
2. I have been playing with timing but so far seems it doesnt take away my very small KR possible false KR? im on E85 not sure whether or not its false but i dont want to risk it...As you can see this coincides with top post. On my file i do notice im almost @ 24 degrees on timing at top of 2nd, when shifting into 3rd with no KR but on 3rd seems im having a bit of KR.. Even when i drop 3degrees of timing.
3. I have a 7 disc vig i lock it @ 75 mph.. im trying to figure out if my trans is flaring or how well my converter couples my rpm seems to drop only a couple hundred rpm's?
I would really like to kinda go 30 psi this weekend with no hiccups i want to spank some ppl up... also not sure if this matter's on the tiny bit of KR but im running 42ts's gap'd @ 32.
Should i add more fuel to the tables on 3rd?? i have added 6-7% with no change to BL's being over 140 on top of 3rd.... i would like to lean it out a bit im thinking to about 11.2-11.4 maybe that would drop the bl's?
Lastly do you see anything wrong or needing improvement on my tune?? It's just a little tweaking over Eric's chip profile..
both runs were maybe 8 minutes apart once i reviewed my 1st run i made some changes to timing and fuel which you should see on the 2nd run
the 3rd run was an older test run maybe has some other insight it was a little colder that day..
I have noticed my boost rdgs are extremely erratic my boost controller sucks!!
