New to the Grand National, but looking forward to the learning. Got a 87 and here's a few of the things done.
> New Radiator
> New MAF
> New Transmission
> New 02 Sensor
> New Paint.
> New bumper fillers
> New GM Antenna
> New GM Window weather felt seals
> New GM Weather strip
> New GM Power window switches
> New GM Power door lock switch
> New GM Center cap
> TA49 Turbo
> Terry Houston stainless steel 3" Down Pipe
> Hooker Headers Not installed
> New 3" Front intercooler with pipe kit
> New 3"Alum K&N Cold Air Kit
> #43lb injectors with chip to match
> Red Armstrong Chip 93 and 107
> New Red Armstrong fuel pump
> New Red Armstrong fuel regulator
> New Fuel Filter
> New vicparts 160 Thermostat
> New Hotwire kit
> New KDK FIT plug wires
> New G-Power plugs
> New Rubber Valve cover gasket
> All New vacuum hose
> New hose reducer-T-Bolt Clamp
> New Console gauge pod
> New Console Cushion still in box
> New shift T-handle just becuase the original was little dirty
> New headlight covers
> New Boost Gauge
> New Fuel pressure Gauge
> New Waste Gate Solenoid Filter
> New Fel-Pro 3"downpipe Gasket New in package for TA49 TURBO
> AC Delco AM/FM CD
> New Battery
> New Battery Retainer
> New custom floor mats
> New Full front fender cover
> New Scanmaster
The Service engine light stays on and I read that is normal with a aftermarket chip. Car has 57,000 on it. Has what i heard are some rare options. Has the astro roof & digital dash. ( U52, CF5 ) Haven't check yet because of weather to see if the chip is a red armstrong, but I'm guessing it is. Plan on just cruising it this year and want to hear any suggestions?? Also put pics in profile album. Thanks in advance.
Also have all original parts that came with car. Also have a laptop and wondered what I should get to tune using it.?? Sorry for the long post.
> New Radiator
> New MAF
> New Transmission
> New 02 Sensor
> New Paint.
> New bumper fillers
> New GM Antenna
> New GM Center cap
> TA49 Turbo
> New Fuel Filter
> New Hotwire kit
> New G-Power plugs
> All New vacuum hose
> New Boost Gauge
> AC Delco AM/FM CD
> New Battery
> New Scanmaster
