jskarateka
- Nov 16, 2008
OK guys, I'm going to try and be as complete as I can because I may not be able to respond to any reply's for a day or two. Most of the 'cool guy' parts I have are listed in sig. I've been trying to get this thing to do a high 11 for a long time but I suck at tuning. It currently runs upper 12's with a best of on last time out:
60'..........1.773
330'........5.115
1/8..........7.947
1/8mph..87.02
1000'......10.404
1/4..........12.498
1/4mph..107.34
That was with the TT alky chip, which was burned for the combo in my sig, and left the way Eric set it.
- About half 93 octain, half 100 octain in tank (for a little safety)
- Sunny 83 degrees, track prep fair
- Tire pressure 18 lbs
- Leaving at 5 lbs (any higher would spin)
- Alky dial at 6.5 (running denatured)
- Boost at 22#,
- Timing was 22.9 in 1st, 20.8 in second (Eric's settings)
- No knock
- Narrow band O2's at .811 (wide band setup is next project)
- Shifting at 5K
- Crossing finish at about 5100
- Not locking converter, not shifting into OD
- Runs and pulls steady, no stumble, no 'nose over' at the end
- Did not try opening dump pipe (sort of forgot about it)
- Turned the boost up to 25#, MPH dropped about 1mph which surprised me.
- Left boost at 25# and added 3% overall fuel, no change (still slighty slower).
- Left boost at 25# and subtracted 3% overall fuel, no change (still slighty slower).
- Put boost back down to 23# and chip back to Eric's default setting, MPH went back up to 107.
- Left boost a 23# and took 3% out of 1st gear fuel only and added .7 degree overall timing. (still 107)
No knock on any runs but I do not have all the run logs saved.
I'm far from an expert with these cars but I'm not exactly a newbe either. I've been working on this car, racing it, and reading tons of posts on here for several years now but I can't seem to get it into 11's which many have achieved with far less 'cool guy' parts than me. I guess my main request is for any general advise, procedures, recomendations, on tuning for my particular issue. Any would be appreciated and thank you in advance.
Power logger file is attached, please note that MPH is reading higher than actual (speedo is off but axle ratio has not been changed).
60'..........1.773
330'........5.115
1/8..........7.947
1/8mph..87.02
1000'......10.404
1/4..........12.498
1/4mph..107.34
- Boost at 22#,
- No knock
- Shifting at 5K
