86GN-862+2
- Apr 19, 2008
Ok gentlemen,
everything seems normal to me but I need expert advice. My car with mods in my signature runs poorly(15's and maybe 12lbs of boost)
scan master readings at idle warmed up:
AF 04
LB 31-33
BAT 13.1v-13.4v
INT 128
BL 123 and goes down from there under load no matter what I do!<<<
MPH 00
CLT 171
ATS 78
Rpms 750-820
TPS .42
IAC 33-36
MAL 00
Fuel pressure hose on about 38psi, Hose off 34.5-35 psi with 237 FPR
X-counts are erratic/normal I guess. Also, what is a safe max RPM for these stock engines while making a run??
When I take it out, the BL goes down to 113-115 even with the fuel set at 150(option 1 and 2 of the TT chip). I got that high in increments of 3-4 numbers. I just don't get any knock retard on the display at all(stays at 00).
Temp climbs quickly to around 210 degrees but I let off at that point. Boost registers 12psi(boost gauge is connected to fpr hose). I need to get rid of the excessive heat as well!! I know lean conditions worsen this but helps me get the BL's high enough
Thank you very much!!
Jr.
AF 04
LB 31-33
BAT 13.1v-13.4v
INT 128
MPH 00
CLT 171
ATS 78
Rpms 750-820
TPS .42
IAC 33-36
MAL 00
Jr.
