Need your help with tires size ?
Thurman stone
Oem GN 87 wheels . Want to lower the car a little . So I'm thinking. 225/60r/15. What do you guys think ?
Factory is 235/60/15 you wouldn't see a bit different? Change the rear to be taller and wider look better.
They would be about .5" smaller in diameter than the stock 215/65/15. I think 225/60/15 would look good with the car lowered 1-1.5"
I went with 215/70-15. They look good with my 275/60-15 out back. Only slightly skinnier than stock.
215/70 is the same width as stock (215/65) just about 27 inches tall whicb is about an inch taller than stock
I have 255/60 15's on the back and I am getting 235/60 15's put on the front. The rears are a little taller but the fronts are the same diameter, 26". My mechanic told me the 235's will rub a little when locked. I really like the look of the 235/255 combo. Looks very appropriate for our cars. I have OEM GN wheels.
I have 255/60 15's on the back and I am getting 235/60 15's put on the front. The rears are a little taller but the fronts are the same diameter, 26". My mechanic told me the 235's will rub a little when locked. I really like the look of the 215/255 combo. Looks very appropriate for our cars. I have OEM GN wheels.
I just got new bfg radial ta's on stock gn wheels in front - 235-60-15. No rubbibg at all, lock to lock, over bumps, whatever. All stock suspension.
Any
Any luck with some pictures ? I mite end up going that route . Thanks
This picture above is my 84 with 235-60 R 15 tires all around
with 1" lowering springs front and rear. Rides good, handles better,
no tire rub. I like them. HTH
Sorry - mine are 225-60-15 in the front. 235-60-15 dr's in the rear. Picrures coming soon. I'm unable to post full pcs of the car as im in the middle of a vac brake swap and hit a snag (see yhread above this one. As soon as i can i'll post full pics. Theres plenty of room. I shoulda put 235's all yhe way around.
This post done with the new turbobuick iphone app. Pretty friggin sweet and user-friendly.
All of my cars, 2 with 1" lowering springs all around and the
stock 18K mi., 87 Gn all have the exact same ride height
differential, front to rear, of 5/8". I was impressed with this
result, since I made no effort to acheive it. Just installed the
springs and Bilstein shocks and there it was!
