turbov6joe
Signal 1 J-12
- May 22, 2002
If you had your choice between a Hoosier QTP in a 26x9.5x16, Mickey Thompson Street ET in either a 26x10.5x16, 26x11.5x16, 27x10.5x16, 27x11.5x16, 255x50x16 BFG Drag radial, or an M&H Racemaster in a 305x50x16 what would you choose for strip use?
I need to replace my VERY OLD and worn MT street ET's (26x11.5) before BG and am on the fence with what to buy. I wanted to try the new MT ET radial but they're not available untill late June at best....so now I need to make another choice.
My car has the stock gear, a #6 pump (3800 stall) 5 disc Precision Industries converter, TE45a, and a Stageright T brake. Typically I launch at ~10-15 psi on the T brake, or ~5-8 psi on the footbrake. I would like your opinions and some concrete reasons why I should choose the tire you recommend. I've used or know of someone that has used all of the above tires (on a TR), I'm just making this decision more difficult than it needs to be. HELP!
