Thanks to some old forum posts, I found that the turbo drain gasket I forgot to buy can be made effectively out of a beer box.  I didn't have any but the oil filter box should work just as well.  I first traced the flange with crayon.
Then I cut it out and made it my template for cardboard.  Yes, that was the for sale sign that sat in my car last summer.  It's funny to see how things have changed.
I skimmed some high temp RTV on both sides and left the bolt holes rough.  This way, it holds the bolts nice while I'm trying to attach it to the turbo.  Notice that I messed up and failed to get the orientation correct when I tightened the block side.  I hope this doesn't come back to bite me, but I wasn't exactly interested in taking everything apart to get it right.  I just attached it to the turbo and twisted.
Hopefully I didn't crack it.  I'm not proud of what I did, but this pipe is a lot stronger and more flexible than I thought!
I'm going to see if I can get the heater hose out of my way and release the tension on it. I don't see this holding up to a bunch of heat cycles.  I'm guessing it'll crack if it hasn't already.  For now, I'm continuing on because I need to find out everything else I can mess up.
This looks cool.  Too bad it's going to function worse than before if I leave it like this.  The top two bolts are the only ones holding the elbow on at the moment.  I discovered that the bottom nut was missing because it was never possible to install one, and the second from the bottom is stripped out.
Again, I wasn't interested in removing the turbo after compressing the gaskets.  I removed the external wastegate block plate, covered the boogered hole from the inside, and made my right angle drill useful again.
Now it's going to have a mismatched bolt, but that's fine.  It's a good thing the other bolt holes were not an issue because the casting quality of this BGC elbow is not too good.  I do not have room to drill the other holes bigger.
Speaking of crappy casting, this is the lowermost bolt hole.
You certainly can't get a bolt in there, but you can't even spin the nut on a stud.  I'll need to grind away some material so that I can install all the fasteners, repaint, and try again.  M wife wasn't feeling great though, so I didn't want to make all that noise.  Maybe today I'll get to it.
I did decide to put the intercooler fan back on afterall.  I thought with a stock crank pulley, the front of the engine just looks incomplete.  I blasted and painted the junkiest hub I had, and bolted it to the nicest fan.  It's dirty in the picture, but it'll clean up nicely.
