Jon Early
- Dec 4, 2014
This project snowballed like every other. The mold is different from the pod I removed. This taper is a lot sharper which means I need to move it further down the pillar if I want it to fit even remotely close. Great.
But since the old one was screwed in, moving it down means I expose a hole.
I'd also have to make the passthrough bigger, so at least I'll have plenty of filler material.
Good as new? No, but I think paint will go a long way.
I'm not done though. This pod doesn't fit worth a s***!
The issue is only at the very bottom on the inside, so you should only ever notice this cut through the windshield. I'm not at all happy about needing to modify a part that's molded specifically for my car, but I'm still pretty sure that the pillar pod on the A-pillar is not a long term solution. I just want this to look better than what I removed.
