- Nov 30, 2009
Jon , stop by our tent with the WH1 & GN with NY plates
SignUp Now!That's a crying. Shame because the car looks so beautiful Jon. I would just go through your steps again. If it came off and it was looking good. It should go back on. Maybe the antenna wasn't installed correctly and that's why it's pushing it out. But I don't blame you for trying to body shop but find a good one that has some knowledge about g bodiesThanks everyone!
I bought an antenna repair kit and removed the old assembly, but I'm dreading the process of putting it back in. The fender did not come off without a fight, and it certainly doesn't want to go back into place. Due to unforeseen circumstances, the car has been in storage with a poorly aligned fender and no antenna ever since early June. I'm hoping to get the car back in my garage very soon, but I may talk to a body shop about getting the fender put back on correctly. For some reason I had to put all my body weight against the fender while tightening the screws in order to get it even remotely close. Judging by all the videos I've seen of the process, it shouldn't be this hard. I might just have a local body shop deal with it once I get the antenna is back in.
You can kind of see how the bottom of the fender is bowed out. With the tape removed, everything looks terrible.
The antenna isn't in it right now so it can't be that. I knew it was going to be trouble as soon as the fender came off because it took way too much force to happen. Judging by all the issues I've had with fitting air dams correctly (another job that shouldn't difficult at all) I'm starting to wonder if this thing was in an unreported wreck. Nothing in the front end fits like it should and the hood has for sure been repainted.That's a crying. Shame because the car looks so beautiful Jon. I would just go through your steps again. If it came off and it was looking good. It should go back on. Maybe the antenna wasn't installed correctly and that's why it's pushing it out. But I don't blame you for trying to body shop but find a good one that has some knowledge about g bodies
I was thinking about what you said at the Nats about these antennas every time I ran into an issue with mine.Jon , since you like to build things this might help with your mouse problem . I made one myself and they work .
pestkill.org/mice/bucket-trap/
The first one I built , then I found that exact same one you found on Ebay and it works great !! When I put it out in the unheated pole barn I used RV antifreeze .I do love building stuff! I was planning to make something similar until I found these 5 gallon bucket traps on ebay. Hopefully they'll catch the ones who go unfazed by the moth balls.
I put some poison pellets out. So far they have been nibbling on it outside but none that I can tell inside the garage.The best way to get rid of mice is poison blocks. Trapping them you'll just be chasing your tail.
