If anyone can help me get this beast running I know it is this board!!!
A little back story - I rebuilt my 4.1 with the equipment in my signature. I got everything put back in the car and buttoned up, turned the key and it runs great for about 5 seconds and then dies, it acts like it runs out of fuel. I am able to force it to run by pedaling the throttle but if I lift off the throttle or hold steady on the throttle it stumbles and dies. I need to update my signature because I also installed 80# injectors from TT and a new TT chip that Eric made for me. I have been at this for a couple of days so let me list what I have checked so far...please forgive me if I forget something because I feel like I have tried everything but it has to be something simple.
1) Fuel Pressure 43 PSI at the rail verified by Autometer in car gauge. It stays solid at 43 PSI when running and doesn't fall when it dies
2) Translator Plus settings - Toggle switches ON,ON,ON,OFF all dials set to 0 (Zero)
3) ECM verified with known working unit
4) NO Vaccum Leaks Detectable
5) Caspers Cam Sensor with LED so I feel pretty confident it is set right
6) Checked adjustment of Crank Sensor
7) New 103 Octane Fuel
8) SES Light blinks once then solid
9) New Plug Wires
10) New Plugs
11) All Grounds on the back of the motor are mounted firmly to the passenger head.
12) O2 Sensor brand new (Caspers Heated sensor)
13) TPS reading .36
14) IAC Reading 140 (Iread that Eric sets them this way for initial startup to reduce startup high idle)
15) BL is 128
16) No Error Codes
17) AF is 04
18) Scanmaster is reading RPM values
19) New Fuel Filter
I am sure there is something I forgot but I will respond to any questions and appreciate any support offered. This TB.Com community is by far the best board I have ever been a part of and I have supreme confidence that we can figure it out together. I am ready to go drive this baby...I bought it as a basket case and haven't been able to sit behind the wheel yet! HELP!
Thanks in advance!
9) New Plug Wires
10) New Plugs
13) TPS reading .36
15) BL is 128
16) No Error Codes
17) AF is 04
19) New Fuel Filter
Thanks in advance!
