New 86-87 Turboregal Gasket Sets
Red Regal T
Senior Member
WHY ARE YOU PAYING MORE?
2 COMPOSITE TYPE HEAD GASKETS
.........appear identical to felpro head gaskets
1 CORK OIL PAN GASKET
2 CORK VALVE COVER GASKETS
1 NEOPRENE FRONT COVER SEAL
1 NEOPRENE REAR MAIN SEAL SET
1 O-RING FOR WATER OUTLET
6 VALVE STEM SEALS
7 FUEL INJECTOR O-RINGS
1 TIMING COVER GASKET
1 WATER PUMP GASKET
2 EXHAUST MANIFOLD GASKETS
1 OIL PICKUP SCREEN TO BLOCK GASKET
1 THROTTLE BODY TO PLENUM GASKET
1 UPPER PLENUM TO INTAKE MANIFOLD GASKET
1 VACUUM BLOCK GASKET
1 TURBO OIL RETURN GASKET
1 OIL PUMP GASKET
1 CAM SENSOR DRIVE O-RING
1 DRAIN PLUG NYLON WASHER
Don't forget, neoprene front and rear gaskets which cost over $25 anywhere................. ARE included.
SAVE A LOT !!!................................$115 includes shipping
ROL gaskets are quality gasketos and are sold all over the country. Autozone sells this very set for 86-87 TRs for $180, last time I looked. Additionally, I include the neoprene front and rear seals that are not included in the Autozone set. AMERICAN made. You can't beat the price. I've sold many sets here, and I use them all the time myself with no problem.
6 VALVE STEM SEALS
1 WATER PUMP GASKET
1 OIL PUMP GASKET
