SignUp Now!Short answer will the piccolo work well for R134? Yes. Is it the hands down supreme cooling best option? No.
can you post a pic chuck? thanks!Back to "dual/multi pass" condensors.....How to tell the difference???
I just got the Modine pt # 7-4013. [Crossed to it from the Ready Air 2035.]
It looks just like the original part off of my 86T.
It has a looped tube end opposite the in/out lines, and a manifold that feeds the core w/ individual lines.
This is the Modine and a stock condenser...can you post a pic chuck? thanks!
While we are on the subject of compressors here some pictures of the one I got from Highway Stars. New GM. Notice that the connections for the line block is different. Stock used regular o rings and the replacement uses seals that go over the ends of the line block. Both seals stick out of the compressor the same amount and they call for a 1mm gap between the compressor and line block when installed. I am wondering what those two inserts are for though? The discharge port is the only place it could go and not sure what the purpose of them is? Anyone else go thru this?
View attachment 250993 View attachment 250994 View attachment 250992
any update on fitment of the modine condenser chuck?
Very obvious that the newer core is much more efficient. Fin count, along w/ tube count is impressive. I'm going to go ahead and use it.
View attachment 250883 View attachment 250884
Do your hoses not have 5/8 pilots on the block Mark? I just rebuild my a/c with that exact compressor from Glen.Have to look into this some more, obviously can only go in the discharge port as the suction side is a huge hole! I just don't see what purpose the insert provides. Either one is just loose inside the port. pics show them tilted in the port so you can see what they look like. Bigger end is same size as the pilots on the hose block. Smaller end does not fit into the pilot of the hose block. Only thing I can think of is they want the refrigerant to flow thru the piping from the port and not put pressure against these new design seals??
View attachment 251000 View attachment 251001 View attachment 251002
