NEW BIG PARTS LIST 8/10, bought more parts cars
Intercooled88s
Moderator
GN rearend(8.5 Posi, drum to drum, with correct GN driveshaft) $650
Driveshaft for 8.5 rearend $50
Transmission cross member $40
87 GN good running 109 short block $700
87 Engine complete, has a rod nock $2000
86-87 GN wheels good for cores all 4 for $120
INTERIOR
86-87 GN seats $400
86-87 GN lower door panels $60
chrome/grey upper door trim(strips) $25 per strip
Grey rear sail panels(panels around the quarter windows) for t-top car in great condition $40 for both
Grey Third brake light $20
85-87 GN seat belt set(10 pieces) $70
I have all the plastic interior pieces for a marroon or grey car with either t-tops or hard top .
Nice grey arm rests $15 for both
Nice blue passenger visor with lighted mirror $25
Gauge surround $35
radio surround $25
Stock GN radio $50
Maroon dash pad $110
Blue dash pad $120
Grey dash pad $110
T-TOP trim around the t-tops on the inside of the car in Red, Maroon, or grey , all 6 pieces $100
ENGINE PARTS:
86-87 Turbo $150
86-87 Turbo can be used as a core $75
84-87 Turbo elbow $25
86-87 MAF $80
GN Front bumper $130
GN rear bumper $100
Alum. rear bumper reinforcement $80
85-85 ECM $40
86-87 ECM $70
Engine frame mounts $35
86-87 dipstickand tube$40
86-87 Factory Oilfiller tube and cap $30
86-87 Scoop for airbreather $20
N/A crank std./std. $40
109 Block $300
crank $325
.020/.020 Turbo crank fresh from the machine shop $150
stock 8445 heads needing rebuild $40 a set
84-85 GN intake $40
86-87 fuel rail $35
84-85 fuel rail $25
Any year injector harness $30
84-85 valve covers $35
86-87 valve covers $35
cam position sensor just the lower part(no cap) $25
84-85 MAF $45
84-85 AC compressor $40
84-85 Alt $35
84-85 turbo adaptor $25
84-85 crossover pipe $35
84-85 Alt $30
8445 heads $40 a set
84-85 engine wire harness $145
86-87 engine wire harness $175
Any other harness on the car e mail I have them all
86-87 Power steering pump $60
86-87 AC compressor $70
86-87 Belt tensioner $70
86-87 Alt. $60
86-87 Main accessory Bracket $80
84-85 Main accessory Bracket $50
Small plastic guide that holds the posi bat cable to the lower front cover $20
84/85 to 86/87 conversion parts(all the original GN parts you need to convert over from 85 to 87) $1500
Oil cooler adaptor with nut $35
Timing cover $30
Turbo rods(2 dot) $40 a set of 6
Turbo flex plate $25
Turbo oil pans $35 each
84-85 control module $50
84-85 coil pack $40
87 GN steering box $40
Fuel pump hanger/sender $50
Turbo gas tank $40
GN sway bars $30 each
windshield wiper assembly $15
Complete heater box $100
Body & Misc.
BQ coded GN transmission 48k $300
BRF tranny $500
Stock 200 4r tranny pan $35
Drivers missor $20
Passenger remote mirror $40
Blackout door handles $25 for both
GN Spoiler(GM not after market) all 5 pieces $175
Non Key locking t-top $90+shipping for the set
86-87 Locking t-tops
T-top bags $35
GN tail lights with blackout trim $100
Quarter glass with blackout trim $80
3 piece windshield blackout trim $30
3 piece rear window blackout trim$20
Black wheel well trim $50 each
Turbo plastic wheel wells $80 each
Any other blackout piece e mail me
GN hood $95-$150
AC lines $45
Blue dash pad $120
E mail me if you need a part not listed Fortune628@aol.com I most likely have it.
or CALL ME at 413 746 9668
I am in need of a Drivers side lower door panel for my GN. Are the ones you have CSII? And what kind of shape are they in? Do you have any photos available? Thank you for your time.
Matthew
I dont have Concert sound lowers just the standard GN lowers. If your still interested I can send pictures.
Basically I am looking for the Plastic part and arm rest, can I combine my CSII with that> Mine got smashed up the other day, (check the thread in the turbo lounge)
If I can combine the two please send some pictures if you get a chance. Thanks again.
Matthew
The concert sound speaker covers bolt on to the non CC2 lowers, if you take you panels off you'll see that GM hacked up the lower to screw on the concert sound speaker covers. Are your arm rests damaged? They are attached with screws also and can be removed from the door panels. Just suggesting , but if you need the arm rests I have them also.
Hello,
Do you still have and if so....what kind of shape is the plastic top dash speaker/defrost vents plate in Maroon/Burgandy??
Thanks!
By any chance, would you also have the plate where the ignition module sits on and the bracket that holds it up, and a set of stock valve covers, everything for an 87? If so how much?
