SignUp Now!hose from pvc to one inlet oil drops in can the other outlet goes to throttle body with check valve in line so it doesnt pressurize can buy check valve from link that bandaid put on. you might as well buy th 1/4 inchers to replace the factory ones there only $1 or so49-blues said:do you have a diagram how you plumbed this can into your system? do the valve cover breathers get piped into this?
dont worry about not getting it i got mine in 4 days. there are gaskets for the two inlet valves put form a gasket on them and the threads to make an air tight seal when you take off the inlet valves. one has a longer tube than the other one. the longer one goes to the pcv valve the shorter tube goes to the throttle body. put a check valve in between the throttle body and the can so to not pressurise it also there should be no building crankcase pressure with those COOL new valvessalvageV6 said:Got a payment confirmation from them today, that's a good sign.![]()
Tracking info. should be valid in a day or two they said.
Hopefully I'll "get it".![]()
Now to order a pile of cool check valves.![]()
I know most of the water separators use mesh probably not needed for the oil.
Just got mine delivered. There is problem with the "check valve" that was in the kit (does not check ......LOL). Two machined AL pieces connected with some hose. One AL piece does not have a hole (looks like may be the drill broke during machining and they never caught this). One would think they would have caught it in the assy process?lpaulabbott said:hose from pvc to one inlet oil drops in can the other outlet goes to throttle body with check valve in line so it doesnt pressurize ...........
Jerryl said:Just got mine delivered. There is problem with the "check valve" that was in the kit (does not check ......LOL). Two machined AL pieces connected with some hose. One AL piece does not have a hole (looks like may be the drill broke during machining and they never caught this). One would think they would have caught it in the assy process?
I will contact the supplier. Just wondering if anyone have a problem with this?
That to the the 1,000,000 question.HellOnWheels said:YES!! same here.
Even tho it wasn't drilled what in the heck is it for? HOW
yes it has a aluminum one with an o ringTrboHead said:Does it have a cockpit or drain on the bottom? I guess you could put one in.
Well the seller responded and appologized for the quality control issue.HellOnWheels said:YES!! same here.
