New combo.... opinions, comments please...
trbojo
'Stang Stinger
109 block .030 over 50% hard fill
eagle forged crank
k-1 rods
diamond forged dished flat tops 8.5 - 1
billet center mains
champion gn1 heads aluminum fully ported and champion stock ported intake
comp 212 212
turbonetics 6665 bb
ta headers
93 octane and dual nozzle razors
everything else in sig should be the same
Sounds like a beast, but surprised to see the hard fill. Will the car be driven a lot on the street? Curious if the hard fill would affect cooling...
mostly street...i had the same concern..engine builder said it won't be a problem.. he said the main reason for doing it is to keep the cylinders from ballooning at higher boost levels...
So, did he hard fill it half way up or half way down? In other words, is it on the bottom near pan rail, or near the top near the head surface?
it's running....feels like a beast at 18psi on 93 and a little alky..was showing a little lean on the wideband at first but i was starting to get it dialed....then the trans blew up!!! conveter is trash, took the pump with it, and obviously everything else....out getting done now..
