Turbo Negro
Lookin' for 10's
- Jul 5, 2012
It's been awhile. I have not been able to make any hardware changes to the car, as suggested above, but still wanted to play a little while the weather was cooperating (mid 50's with a -DA). Had the boost turned down from my previous high 10 second pass which was done back in Feb last year in similar air.
With the boost now set at 30-31lbs, a couple additional degrees of timing advance, and a slightly leaner AFR, last Wednesday night the car went the exact same ET (10.967) as it did before. Leaving with about 8-10lbs, I rolled out to a modest 1.60 60ft and went 121.5 MPH. I was happy enough with the result to have at least backed up my personal best, and improve the MPH (this is now the fastest it's been), that I decided to quit while I was ahead, and not push the car, tune, or my luck any further for the night.
I still think there's a little left, especially with a harder launch and better 60ft. But it may be another year and require a new set of tires before I can find out!
Once again, I could have never made it this far without great support and lots of help. Thanks to all (you know who you are)
