New Fittings / Fuel Line E85 Compatible
87chrisss
BLUBYU
I have a full complete -8 fuel setup all fittings even have a -8 Aeroquip Fuel Line E85 compatible 19 feet long. I also have a stock Fuel Rail with a -8 Fuel Feed Fitting already mounted on rail.. Would like to sell complete kit for $225 includes shipping
I would like to keep as spare but i need some $$ for slicks..
I will try to explain as best as i can..
19 ft of Fuel Line Aeroquip
Here is the way i had it planned out it consisted of -8 fitting from tank to line to a -8 female to
male reducer -8 to-10 for the fuel filter (i was planning on using a Aeromotive stainless steel micron filter which is -10) then out of the filter another male reducer from -10 to -8 to a female -8 straight back onto the line up to the front which goes on the fuel rail. I was either going to use a -8 straight female or a 90 degree -8 female onto the male -8 on the fuel rail. Then i bought some -6 for return. Check Video all of the fittings are new never been used.
You might want to put this info in the E85 section as well.
