Drewster
Wish I Had A Clone. AKA Andrew Youlio
- May 31, 2001
This ones has me a bit stumped. I just installed a new fuel pump and hanger, I primed the pump before and after installation (using pump prime connector and fuel rail hose to can) no problems. When i went to start, it stumbled and would not run. i added more fuel and checked the prime again, prime was good. i decided to run the pump more but with closed system and check fuel pressure. After seeing no pressure for a bit, i realized my electric fuel gauge needed the key on, turned key on and saw about 90 psi, I adjusted the regulator down as far as it would go, got pressure to about 65 shortly after i had fuel comming out of my EGR valve. WTF! tried to run the engine and it was hydrolocked, not turning over. so apparently i have leaking injectors or they just cant handle the high pressue. I took all the spark plugs out and cranked the engine, blowing the fuel out of 3 maybe 4 of the cylinders
still no start after that mess, the pressure comes up to 40psi on a start cycle of course the gauge turns off while cranking so i cant see what i happening.
heres what ive got planed
change the old billet aluminum regulator
install a mechanical pressure gauge
test the return line for restrictions
Anyone have a high fuel pressure problem after a pump install before?
anyone Fuel Hydrolock a motor before and how long before it would dry up and start?
Bruised but not broken,
Andrew
Andrew
